show access-list counter
show access-list counter {countername} {any | ports port_list | vlan vlan_name} {ingress | egress}
Description
Displays the specified access list counters.
Syntax Description
countername Specifies the ACL counter to display.
port_list Specifies to display the counters on these ports.
vlan_name Specifies to display the counters on the VLAN.
ingress Specifies to display ingress counters.
egress Specifies to display egress counters.
Default
The default direction is ingress.
Usage Guidelines
Use this command to display the ACL counters.
The following example displays all the counters for all ACLs:
# sh access-list counter
Policy Name       Vlan Name        Port   Direction
    Counter Name                   Packet Count         Byte Count
temp              *                15     ingress
    mac1                           0
    mac2                           2720
egressdeny        *                15     egress
    mac01count                     0
temp              *                20     egress
    mac1                           0
    mac2                           0
The egress option was first available in ExtremeXOS 11.3.
Platform Availability
